changing animation time
COW Forums : Autodesk Maya
joe
by
on Mar 25, 2006 at 9:41:11 pm
I have a bunch of dominos knocking each other over which is now a baked simulation, the time it happens from is 1-400, however I would like to change it to 120-520, Thus adding some time before the animation takes place, I'm trying to do this through the graph and dope editor however my efforts so far have been futile. Any advice would be wonderful!
Chad Briggs
Re: changing animation time
on Mar 25, 2006 at 10:25:59 pm
Have you tried just selecting the keyframes and scaling them in the graph editor with the scale tool? One bad thing i can forsee with that is that your keyframes will no longer fall on whole frames.
-chad
mYthprod
on Mar 29, 2006 at 6:42:36 pm
You can shift-select them in the time slider and expand, contract and move the keyframes. You may run into the same thing that Chad said in that they won't fall on whole frames anymore. Not sure if there's a setting in maya to only land on whole frame numbers.
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
_______________________________________
Supermicro X5DA8, Dual Xeon 3.0 GHz
Windows XP Pro, SP1
VelocityQ, Version 9.1.36, Quattrus 140
