hiding a parent without the child
COW Forums : Autodesk Maya
cowcowcowcowcow
joe
by
on Mar 22, 2006 at 2:32:17 am
I'm trying to hide a parent but i want to keep the child visible, how can i do this? I can't seem to select the parent without selecting the child.
mYthprod
Re: hiding a parent without the child
on Mar 22, 2006 at 10:42:30 pm
You can click on object, type f in outliner, click on parent and do a cntrl-H and then select children and do a show selected?
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
_______________________________________
Supermicro X5DA8, Dual Xeon 3.0 GHz
Windows XP Pro, SP1
VelocityQ, Version 9.1.36, Quattrus 140
Sean Fennell
on Mar 23, 2006 at 12:17:50 am
you'd have to hide the shape node of the parent to keep the child from getting hidden also. Select the parent and press down arrow to pickwalk down to its shape, and hide. The parent should hide but the child should stay visible. Problem is you cannot keyframe the shape visibility.
joe
by
on Mar 23, 2006 at 8:56:31 pm
hhm basically what im trying to do is replace some proxy objects with the textured higher rez objects. I'll give the pickwalk a try
Sean Fennell
on Mar 24, 2006 at 1:15:08 am
The parent constraint can be useful for this. Parent constraint the hi-res to the proxy and you'll be set, you can hide each individually or make their visibility dependant on each other.
