Importing AutoCad ascii into Maya?
COW Forums : Autodesk Maya
cowcowcow
Emmelai
on Mar 17, 2006 at 4:42:38 pm
Anyone familiar with doing this? I work for a golf course design company and we have been experimenting with importing autocad ascii files into Maya (with the help of a script). The problem is that the orthographic views are switched around. I've tried changing the up axis from y to z and it doesn't seem to make a difference.
Any ideas?
Thanks!!!!
Emily
Graphic Artist
Maya, Shake, Motion User
Steve Sayer
Re: Importing AutoCad ascii into Maya?
on Mar 17, 2006 at 7:05:21 pm
Could you just select everything, group it, rotate it by 90 degrees, and then ungroup it?
-Steve
Jason Brummett
on Mar 18, 2006 at 8:23:39 am
To the best of my knowledge and I haven't used AutoCAD in a few years now, AutoCAD doesn't write out an ascii file ever? Do you mean a DXF or DWF or DWG or what? a native saved as AutoCAD 2002 and earlier DWG file will import straight into Maya without need for anything other than having the FBX plugin loaded.
Jason Brummett
Jason Brummett
Studio Z Inc.
Emmelai
on Mar 20, 2006 at 5:20:42 pm
Hi Jason,
Well, what we have actually done is taken the points from a dwg/dxf and converted them into tabular data ourselves....then saved it as a text file. We have a script that allows us import the text file directly into Maya.
You think the grouping and rotating would work?
Emily
Graphic Artist
Jason Brummett
on Mar 20, 2006 at 5:31:14 pm
if your using Land Desktop or similar package as well and creating an ascii file thats represts a "point cloud" of the golf course terrain, I believe you'll need a customer importer to Maya. What I've done in the past when using a TIN (Triangulated Irregular Netowrk), basically a polygon mesh is to create this in Land Desktop or AutoCAD and export the mesh directly into maya via dwg.
Jason Brummett
Studio Z Inc.
