Distorted image in the image planes in the perspective view.
COW Forums : Autodesk Maya
Time_to_retire
on Mar 7, 2006 at 10:19:51 pm
I'm new to Maya so this problem might just be me not knowing the software yet. Started working through modeling a human figure using Tareq Mirza's "Organic Modeling -1" DVD. I downloaded the images from the freedom-of-teach site and placed the front view image in the front view image plane. and the side view in the side view image plane. The problem is, the images in the perspective view are rotated about 45 degrees with half of the figure going out one side of the plane and the other out the other side. The other two views are normal. Have I got something set up wrong in the perspective camera or is there another problem? Any help would be appreciated.
Chad Briggs
Re: Distorted image in the image planes in the perspective view.
on Mar 8, 2006 at 2:42:46 am
maya has issues with non-squared textures. make sure your image resolution is a power of 2. 64x64, 128x128, 256x256 etc...
Time_to_retire
on Mar 8, 2006 at 10:56:07 am
Thanks Chad for your response.
All the images are jpg images that are 586 X 1200 shots of their resin cast models. In the demo Mirza's perspective window looks normal. I would assume that he is using the same images as I am since I downloaded them from their site. But he is using May 6, I think, and I'm using Maya 7. I wouldn't think that would be the problem. He also has way more experience with Maya than I so if he had the problem he would know how to fix it.
Can you think of any other reason I should be having this problem? Again, I really appreciate your response, thanks.
franky
on Apr 7, 2006 at 7:25:55 am
I'm having the same problem with the image planes in Maya.
With the following GPU: PNY quadro FX 1400
Any solutions yet?
Franky
alidixon
on Apr 8, 2006 at 12:29:01 pm
yes, and i am too getting the exact same problem whilst trying to map blueprints to image planes, i get the exact problem when i map them to planes too...very odd...any more suggestions??
Time_to_retire
on Apr 9, 2006 at 6:54:02 pm
I solved my problem by writing the following lines into my Maya.env file
MAYA_SLOW_DRAWPIXELS = 1;
MAYA_NON_POWER_TWO_OFF = 1;
It worked for me I hope it works for you
cowcowcowcow
alidixon
on Apr 10, 2006 at 9:09:30 am
excellent news, thanks for replying to my post, i cannow go home and try it on the weekend. do you know why the error occured? would be interested to know more,
Thanks, Ali
Morlau
on May 22, 2006 at 2:31:56 am
Dear Time to retired,
I have the same problem and I'm happy to find the solution with you but, where, exacly do I paste these line :
I know you write in the Maya.env file but where is this file?
I would like to have more precision on that issue.
Many thanks to you !
Morlau
