Smoke render problem
COW Forums : Autodesk Maya
R303
by
on Feb 25, 2006 at 12:16:15 pm
I'm trying to make smoke to use it with an earthquacke that i'm building.
I'm using sprites and i've made a 100 smokelet tiff images, witch i'm cycling using expressions.
It looks good and I have no problems with it's behaviour.
My problem is with the rendering. When I render it with the batchrender engine the smoke
comes out jittery and staccato like, but when I render it using the hardware renderbuffer
engine it look nice.
Am I doing anything wrong when rendering the smoke?
Here is a link to the settings I use, and 2 Quicktime movies showing the different renders.
http://www.backstagefilm.dk/problem/problem.html
Thank You.
Daniel
R303
I solved it
by
on Feb 25, 2006 at 3:26:31 pm
Hi htere I solved it. I had to disk cache the particle before doing the batchrender.
