Importing CAD files in to Maya
COW Forums : Autodesk Maya
on Feb 17, 2006 at 7:09:52 pm
I posted this under another thread as well, but I didn't see it unders today's posts...I'll try again.
I work for a golf course design company and we are looking to pull our plans into Maya from Microstation. When we import, I can not see anything. Is there any specific settings for field of view, etc. I should be using? We would also like to import as NURBS should we save the file in Microstation to allow for this type of import into Maya? We are on Maya 6.
Graphic Artist
Maya, Shake, Motion User
Thomas Rydberg
Re: Importing CAD files in to Maya
on Feb 17, 2006 at 8:22:01 pm
Can you try exporting from Microstation in a file format like DXF or IGES? If I were you, I would try some simple tests first. Create a simple sphere or other object in Microstation and try exporting it using different file formats, then see which gives you the best results importing into Maya.
- Tom
******* student *******
"Learning to animate anywhere in the world
from the world's best animators."
Pixar, ILM, Disney, Dreamworks and more.
© 2018 All Rights Reserved
