Playblast only in wireframe?
COW Forums : Autodesk Maya
John Ward
on Feb 9, 2006 at 3:10:22 pm
Hello, all -
I'm relatively new to Maya and was trying to figure out how
to get a playblast of a timeline region with flat shading. I
can't seem to get anything but wireframe. Am I looking at a
feature request or just overlooking a simple checkbox? Any and
all help is most appreciated.
John Ward
Editor / Animator,
Synergetic Productions
john@synergeticproductions.com
315.437.7533
Steve Sayer
Re: Playblast only in wireframe?
on Feb 9, 2006 at 5:14:22 pm
The playblast should use whatever shading settings are in the active window. Have you set the window to flat shaded mode before activating the playblast?
-Steve
bobmotzah
on Feb 9, 2006 at 8:04:49 pm
Playblast is simply a process of capturing screen grabs and stringing them together in an image sequence. If you have wireframe display on your playblasts will be wireframe models. Also if you have wireframe on shaded you would see a a solid object with wireframe outside. To turn off wireframe on shaded go under your view tab and toggle it off. then press the number 5 for shaded view, 6 for shaded/texture view and/or 7 for rough lighting view. playblast from the timeline and it should look how you want. Otherwise to get the best results do a quick hardware render.
John Ward
on Feb 9, 2006 at 8:51:21 pm
I thought I had but I will go back and make sure. Thanks for the
reply.
John Ward
Editor / Animator,
315.437.7533
