text along path
COW Forums : Autodesk Maya
igor
text along path
by
on Feb 2, 2006 at 6:37:24 pm
Im new in Maya.So if can someone help me.How can I make text along path and animate it?I tried with attach with motion path but only first letter goes with path.Thanks!
Sean Fennell
Re: text along path
on Feb 2, 2006 at 7:05:13 pm
group all the letters together, and select the group and then the path. Do the attach to path. Then apply a flow to path, that will create a lattice and make the letters bend around the path....sort of like a snake.
igor
Re: text along path
by
on Feb 2, 2006 at 10:18:37 pm
Thank you very much for help.But, like I said, Im begginer so ,if you have time, please, do it again but now, step by step .Im not sure that I understood.I have Maya 7.Thanks again
mYthprod
Re: text along path
on Feb 3, 2006 at 4:26:31 am
Group the letters - select all, cntrl-g
attach to motion path - select object, then path, animate > attach to motion path
Curve Flow - I think that's under "effects"
Maya has an awesome help system.
Good luck!
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
Sean Fennell
Re: text along path
on Feb 3, 2006 at 5:00:23 am
Curve flow is an animation path tool, its under Animate -> Motion Paths -> Flow Path Object
