Maya - After Effects Z depth crash
COW Forums : Autodesk Maya
frank weber
on Jan 31, 2006 at 5:53:27 pm
I know about the Maya7 Iff issue where you can't get Iff's with Z depth into After Effects. But After Effects also crashes on RLA files out of Maya7. Can anyone help?
Chad Briggs
Re: Maya - After Effects Z depth crash
on Jan 31, 2006 at 9:55:05 pm
The mental ray implementation of Maya 7 has a issue with spitting out IFF files. (as you know). I've been rendering out to the SGI format lately and using that, which seems to work well (not sure if it will support a depth channel or not). probably best if you do your depth pass as a seperate pass via shaders, becasue mayas built in z-depth doesn't alias properly.
