random rotation to instanced object
COW Forums : Autodesk Maya
pena
by
on Jan 22, 2006 at 5:54:07 pm
How can you get random (per particle) rotation to instanced spheres in Maya 7?
Steve Sayer
Re: random rotation to instanced object
on Jan 23, 2006 at 6:29:07 am
I'm not on Maya 7, but I expect that you can use a particle expression just as you can do in earlier versions.
Add a 'userVector1PP' attribute to your particle object, then select that attribute for Rotation in the instancing attributes. Use a particle expression to randomize the vector attribute and you're all set. For random, unchanging rotation values between 1 and 180 (not sure if degrees are appropriate, or if it should be radians), it could be as simple as:
     particleShape1.userVector1PP = sphrand(<<180,180,180>>);
Post again if you need help with any of those steps. Good luck!
-Steve
pena
by
on Jan 23, 2006 at 10:38:44 am
Thanks Steve!
It works.
Pena
