ack whats causing this render output problem.
COW Forums : Autodesk Maya
Bryan Carvajal
on Jan 18, 2006 at 5:12:24 pm
So I finally finish making my head model (still far from perfect)
and have it rotate 360 in a loop and tell it to render out the frames at 720x480...when I check the stuff in AE, it brings it up as 720x240..same with photoshop, 720x240 res...I checked render globals and it said 720x480.
what could be causing this problem as it hasn't happened before and where would I go to reset everything back to default settings on everything in maya in case I have no other choice. This didn't happened til after I started rendering the head. The only thing I have changed is the render/project location and thats it.
Sean Fennell
Re: ack whats causing this render output problem.
on Jan 19, 2006 at 1:02:53 am
you dont happen to have field rendering turned on do you? that will only render half of the frame vertically into two different set of images for interlacing purposes.
Bryan Carvajal
on Jan 19, 2006 at 3:12:32 am
DOHHHHHHHHHHHHHHh
that was it...must have accidently selected it. thanks!
