Render out wireframes?
COW Forums : Autodesk Maya
Bryan Carvajal
on Jan 14, 2006 at 2:43:33 am
Hi i know this is an easy question, but how do you render out wireframes from a model animation? I would like to keep the background black the the actual wireframe white so I can apply screen blending mode in AE to my background menu. Thanks
mYthprod
Re: Render out wireframes?
on Jan 14, 2006 at 5:09:23 am
Use the vector render engine. Turn off the fill option and check the edges checkbox, then choose stroke width and colors.
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
Bryan Carvajal
on Jan 14, 2006 at 6:34:15 am
ehhh... is it in version 4.0? cause I can't seem to find it:( sorry.
mYthprod
on Jan 14, 2006 at 5:17:01 pm
In version 4 you'd want to use the hardware render buffer. Tutorial here:
http://www.jozvex.com/tutorials/wireframe.html
- mYthprod
(John David Hutton)
Bryan Carvajal
on Jan 14, 2006 at 10:35:20 pm
Thanks that did the trick.
