Constant crashes with Maya 7.0.1 Mac
COW Forums : Autodesk Maya
thomas
on Dec 29, 2005 at 2:48:10 pm
I just switched to Maya 7.0.1 on the companys Mac G5, 2x2GHz with 10.4.3 and 4.5Gig RAM and experienced 5 kernel panics in the last two days. Is that my scene or is there a know issue with Maya 7 on Macs?
Butch007
Re: Constant crashes with Maya 7.0.1 Mac
on Jan 28, 2006 at 6:21:39 am
That actually sounds like it might be a hardware issue. Did you just add the RAM? If the RAM is not all original I would suggext taking out all, but the original memory out and then run Maya and see what happens. Kernel panicks typically are more hardware related that software related and can tip you off to having a bad batch of RAM.
