How do you load an image sequence as a projection?
COW Forums : Autodesk Maya
Robin
on Dec 20, 2005 at 4:19:27 pm
So I've managed to import a targa as a projection, but when I click on image sequence to create a moving projection, the projection goes black and the little message window says it can't find the file??!!
What's going on? How do I import an image sequence???
Robin
Re: How do you load an image sequence as a projection?
on Dec 20, 2005 at 4:28:18 pm
To be more accurate the error message I get is:
Warning: Texture file (location of file) doesn't exist, node file1
Well it does exist!
pena
by
on Dec 20, 2005 at 4:39:35 pm
picturefile.001.tga, picturefile.002.tga etc. You have to have dot before numbers otherwise Maya don't understand it as a sequence. I haven't tested new Maya, but on v.5 at least.
Ben Insler
on Dec 20, 2005 at 4:44:52 pm
Also, maya's using the current frame number as the image sequence number, so you have to be sure to set your ofset as well... i.e. if your image sequence starts at image.00550.tga and you don't set your ofset, Maya will say the image doesn't exist until you get to frame 550... because images 0-549 truly don't exist.
Robin
on Dec 21, 2005 at 3:30:27 pm
Pena thank you! It works!!!! Just the naming convention was all. Thanks for you help! You rock.
