MAYA image planes
COW Forums : Autodesk Maya
spirit
MAYA image planes
on Dec 16, 2005 at 1:42:29 am
My front image plane is larger than its actual size. In perspective view side and top views match, but front view is enormous. I cropped all three images using Fireworks, pasted to separate files with same sizes. But Maya doesn't want to take them into account. What should I do then?
Sean Fennell
Re: MAYA image planes
on Dec 16, 2005 at 1:56:39 am
Maya will create an image plane by default as large as the viewport. Which is not good because if you have a viewport maximized it will make the image plane larger than if it wasn't maximized. Best thing to do is create all the images planes with the cameras at default home and the 4 view mode instead of in maximized views.
