can't export to ascii .ma
COW Forums : Autodesk Maya
lestDog
on Dec 13, 2005 at 9:36:10 pm
something weird that has never happened to me.. I just have a poly mesh... nothing else in the scene... i want to export it to .MA.
When I try I get this message
"File contains unknown nodes or data. To preserve this information,the current file type cannot be changed."
So I when the outhliner, the hypergraph, deleted everything except the model.. I still get the same thing.
Ben Insler
Re: can't export to ascii .ma
on Dec 14, 2005 at 12:51:32 am
Try deleting the history on the mesh. Don't know if that will help, but that's what I'd do next.
-Ben
lestDog
on Dec 14, 2005 at 1:22:12 am
Thanks, I did all that.. It's no big deal really because I just exported it as an OBJ and opened it in an earlier version of maya.. which is maya 5.. now I have 6.5 and it's giving me the probs.. maya 5 isn't.
Jason Brummett
on Dec 19, 2005 at 12:51:08 am
What you see in the Hypergraph, Outliner etc. is dependent on what nodes you've allowed it to show. I had several unknown nodes being generated from old plugins scripts that I had stopped using but were being generated and called everytime I launched Maya that needed to be cleaned out.
A simple way is in the command line select -all;
Then unselect your geom etc. then press delete
delete -type "unKnown"; also kills unKnown nodes in a scene etc.
Jason Brummett
Studio Z Inc.
