batch rendering difficulties
COW Forums : Autodesk Maya
mdowell
on Dec 11, 2005 at 10:36:37 pm
I am trying to batch render a simple animation. However, when I open Fcheck to view the rendered frames, I am unable to find them. I cannot find any .iff files. Does anyone know what might be happening, what I'm doing wrong? Any help is greatly appreciated.
Chad Briggs
Re: batch rendering difficulties
on Dec 12, 2005 at 5:29:31 am
If you do a search for mayaRenderLog.txt on your system, it will tell your where the files rendered to. You will usually find this file inside wehrever your mydocs folder goes.
-chad
mdowell
on Dec 12, 2005 at 5:49:39 am
Thank you for your response, Chad. My problem seems to be that Maya (or my computer) isn't actually rendering the animation. I did set the project correctly and followed the path at the top of the Render Globals window. Hours after I execute the batch render command, Maya still "thinks" it is rendering. When I execute the batch render command, Maya asks, "Do you wish to cancel the current render job?" It is a very simple animation consisting of three NURBS spheres...I don't know what gives...
When I open the mayaRenderLog.txt in Fcheck, it says:
IMF error
mayaRenderLog.txt.1 : <10> broken pipe
