hardware render and custom resolutions - how?
COW Forums : Autodesk Maya
anthonymcgrath
on Nov 14, 2005 at 4:10:25 pm
I used to be able to add my own pixel sizes by editing a file that the hardware render buffer looks at when you go to select a preset - the problem is I cannot find it now or even remember what to look for aaarrrrghghgh! can anyone help me out?
ant
vexxed and really needing to render something out big!
anthonymcgrath
Re: hardware render and custom resolutions - how?
on Nov 14, 2005 at 4:41:31 pm
found it! its imageformats.mel which is in programfiles/alias/maya6/scripts/others :D just added a preset to the list and it seems quite happy now
Sean Fennell
on Nov 14, 2005 at 7:19:35 pm
you should be able to create a userImageFormats.mel in your %MAYA_APP_DIR%/scripts directory which lets you append to the system image formats. Its a bit more plug and play, and safer because you don't change system scripts.
anthonymcgrath
on Nov 15, 2005 at 12:53:48 pm
thanks Sean - I remember having to make one of those now haha! cheers - works a treat!
