maya > modelling cables using splines
COW Forums : Autodesk Maya
sodapop
on Nov 11, 2005 at 5:14:48 pm
Is there anyone who can help me out on this. I need to design and animate cables in maya. Is there
a good way of doing this??
Chad Briggs
Re: maya > modelling cables using splines
on Nov 11, 2005 at 6:17:28 pm
sure, just make a nurbs cirlce, make a nurbs curve for the path of your cable, then extrude the circle along the curve. You'll then be able to move the cable wherever you want by moving points on the original nurbs curve.
