Modifier like slice in maya
COW Forums : Autodesk Maya
sheko_pecko
on Nov 10, 2005 at 12:04:16 am
i was a max user for a time and i begin to move to maya for two months.
and when i want to achieve my work , i found myself need the slice Modifier tht i used to use.
i search for this Modifier or equal command in maya , but i failed
can any one help me
thanks for all
sheko pecko
sheko_pecko@yahoo.com
Sean Fennell
Re: Modifier like slice in maya
on Nov 10, 2005 at 1:00:11 am
What does the slice modifier do? There is a polyCut tool under Edit polygons which will slice a polygonal object, or selected faces using a straight guide. There is also a poly split tool which lets you draw the polygonal cut on the model.
Steve Sayer
on Nov 10, 2005 at 6:56:45 am
I don't know Max, but it sounds to me like a Boolean Subtract might also be worth trying...
-Steve
alan lacey
on Nov 14, 2005 at 7:50:24 pm
I missed the slice modifier in Max when I moved to C4D. In C4D a boolean with a cube works well.
Alan
Jason Brummett
on Nov 17, 2005 at 7:12:09 pm
Poly Cut tool is the one your after. Don't need booleans. Apply it to your geom and if you look in the attrb for this node you will see options to just cut polys and also the important part remove polys before cut etc. You can animate this node as well to cut or disintigrate etc your geom over time.
Old MAX guy too but stopped/switched to Maya 4 years ago now...Good luck
Jason Brummett
Studio Z Inc.
