Field Render -- URGENT
COW Forums : Autodesk Maya
Patrick
on Nov 9, 2005 at 4:26:46 pm
What is the correct setting to render out a targa sequence, field rendered, bttm first, 720x486. The fields need to be combined in a single frame.
Pyro
Re: Field Render -- URGENT
by
on Nov 9, 2005 at 5:03:24 pm
In your Maya Software render globals you have several options for working with fields.
Under the 'Fields Options' segment. This is in the Maya Software tab, NOT the Common tab. If the fields come up in the wrong dominance, you can invert the dominance of the animation in a number of ways. Either in your edit system, using a compositor (Shake, After Effects, Flame) or with F-Check.
Patrick
on Nov 9, 2005 at 8:20:26 pm
Thanks Pyro - I knew it was there but, aside from being new to Maya, was having a major brain freeze...
