can i animate extrude along path?
COW Forums : Autodesk Maya
sheko_pecko
on Nov 8, 2005 at 5:44:25 am
i wanna bulid some wires growing along path . using shape and path and the extrude ,and then animate the extrude , is that any way in maya to do that .
when i was using max i use slice modifier . is there in maya modifier like slice . or any command can do that
i hope any one can help me as soon as possible
thanks
sheko_pecko@yahoo.com
Steve Sayer
Re: can i animate extrude along path?
on Nov 8, 2005 at 7:31:44 am
Yes, you can animate extrusions. Leave Construction History on when you do the extrude and select 'partial' for curve range. There was a thread about this not too long ago, do a search.
-Steve
