Help.New to Maya/MEL
COW Forums : Autodesk Maya
on Oct 23, 2005 at 3:10:15 am
I wanted to emabark on my first MEL script. I thoutght it might be good to try changing the Attibutre names on my camera to "pan" "tilt" "track" etc does anyone know haw I do this? - sorry very green.
Steve Sayer
Re: Help.New to Maya/MEL
on Oct 24, 2005 at 6:45:48 pm
To the best of my knowledge, you can't change the names of default attributes.
You could, however, add some custom attributes to your camera, name them whatever you like, and then connect them to the default transformation attributes. Then when you edit your custom 'roll' attribute, the camera's default 'Rotate Z' attribute will automatically change too.
None of this needs MEL, but if you're looking to practice it, you can certainly use MEL. Look up the commands 'addAttr' and 'connectAttr' for starters.
© 2018 All Rights Reserved
