Exporting a May 7 file for use in 6.0
COW Forums : Autodesk Maya
cwise73
on Oct 19, 2005 at 9:15:01 pm
Sorry for the Newbie post, but I was wondering if someone could point me in the right direction for saving or exporting a file that was created in 7.0, for use in 6.0. I tried using a basic MayaBinary file but had no luck. would MayaAscii work better? Are ther any issues that I should be aware of? Thanks very much in advance!
Chad Briggs
Re: Exporting a May 7 file for use in 6.0
on Oct 19, 2005 at 9:21:34 pm
what you need to do is save it as a maya ascii, then open it up in a text editor, the first ten lines or so will make reference to "maya 7.0" you need to change the version # to whatever version your going to be opening it in, save, and then it should work.
-chad
cwise73
Thanks!!!(NT)
on Oct 19, 2005 at 9:33:28 pm
No thread - Thanks for the info!
