Paint effects Question
COW Forums : Autodesk Maya
Glenn Moore
on Sep 30, 2005 at 6:57:51 pm
I know it's been a while guys and you probably missed me so here goes....
I'm adding an Oak Tree forest to a scene and, at first, it appears that all goes well. When I zoom in to the trees, I notice that they are all oriented 90 degrees (i.e., laying on their sides). I don't recall having that problem before unless I didn't notice the orientation. What is the setting that sets orientation? I can't find it.
Thanks in advance.
Steve Sayer
Re: Paint effects Question
on Sep 30, 2005 at 9:11:23 pm
Check your brush node. Probably the 'Tube Direction' attribute is set to 'Along Path' instead of 'Along Normal'. Although it could also be the 'Elevation Min' and 'Elevation Max' attributes...
-Steve
Glenn Moore
on Oct 1, 2005 at 5:41:07 am
Thanks Steve. That helped.
