caching fluid fX?
COW Forums : Autodesk Maya
jdonnelly1977
caching fluid fX?
on Sep 23, 2005 at 6:13:39 pm
Whenever I try to cache fluid fx, it seems to work until I go to render the scene. For some reason Maya completely disregards everything and starts calculating the fluids from the very beginning of the timeline instead of starting at a specific frame.
Scott Broad
Re: caching fluid fX?
on Mar 7, 2011 at 4:03:45 pm
I know it has been quite a while but did you find a solution for this? I am having the same issue now with maya 2010.
Cached the fluid, renders individual frames just fine in maya. Will not render correctly in batch mode or on a render farm.
