returning item to the grid
COW Forums : Autodesk Maya
joe
by
on Sep 20, 2005 at 4:02:59 am
I have an object that is lost in space far far away from the grid. I cant just set its postion to 0,0,0 cuz i think its transformation was frozen. Is there an easy way to return it to the grid?
Jon W.
Re: returning item to the grid
on Sep 20, 2005 at 5:54:58 am
a nice little trick someone told me about is to: select your object, move tool, hold down "x" then middle mouse drag it anywhere... it will snap to the grid coordinates of where ever your mouse is :)
helpful little thing when your working on a scene far away from the origin and need to make a poly cube at your current coordinates.
mYthprod
on Sep 23, 2005 at 2:32:34 pm
Sweet, Jon. Thanks for that one! :-)
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
Steve Sayer
on Sep 20, 2005 at 6:14:21 am
You mean the object is, technically, positioned at 0,0,0--but the points that make it up are way off in the distance?
First, use Modify -> Center Pivot, then move it back to the origin (by snapping or entering numeric values).
-Steve
