HD frame rates
COW Forums : Autodesk Maya
HD frame rates
on Sep 18, 2005 at 5:29:35 pm
When rendering out animation that will be comped into HD footage that has a frame rate of 60 fps should I double the amout of frames I would normally render out for 30 fps?
ahhh.... adjusting to the HD world...
The Bezier Kid
Re: HD frame rates
on Sep 23, 2005 at 8:27:12 pm
I think that would work. I believe the final frame rate is defined by the editor and his/her editing software given the total amount of frames. There is a frame rate setting under timeline playback in the preferences. It's (twice 60fps). The one and only time I worked in HD The guy laying it to tape said any frame rate would work. ?!? Really no standard in HD. The whole process was pretty frustrating.
© 2018 All Rights Reserved
