Booleans Difference deletes polys
COW Forums : Autodesk Maya
massive3215
on Sep 13, 2005 at 4:43:27 am
I'm trying to use Booleans => Difference but everytime I use it, it deletes both objects. I've tried the other booleans operations and the same thing happens. I've also tried deleting the history of both objects and this doesn't work either. Does anyone have any ideas why this is happening?
Jason Brummett
Re: Booleans Difference deletes polys
on Sep 14, 2005 at 9:50:02 pm
your polygon geometry is Non-manifold. Booleans don't work on Nonmanifold geom. Do a cleanup polygons on your geometry to identify bad geometry then boolean will work %100 of the time.
Jason Brummett
Studio Z Inc.
