Rendering Floating Objects.
COW Forums : Autodesk Maya
toby1kinobe
on Sep 11, 2005 at 8:01:13 am
I've created an ocean, which is animating in playback and redering fine, however when i ad an object (cube) and make it float "make motor boats", it will animate fine in the playback but when i render out a short clip (approx 50 frames) the ocean animates but the object itself doesn't. The ocean still intersects around the object, spills over the edge etc, but the object doesn't move at all.
Any thoughts???
Tom
Re: Rendering Floating Objects.
by
on Sep 11, 2005 at 3:38:52 pm
what platform?
what maya version?
