Turning off render backfaces while vector rendering
COW Forums : Autodesk Maya
mYthprod
on Sep 6, 2005 at 4:40:06 pm
The vector renderer works great for wireframe but is there any way to turn off the back faces so it doesn't render so convuluted? I've tried going into the attribute spread sheet and turning double sided off for all objects with no luck. Do I want some sort of backface option turned off? I've tried edge detail but 90 is the highest it will go to.
Any thoughts?
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
