render logs
COW Forums : Autodesk Maya
mYthprod
render logs
on Sep 2, 2005 at 10:36:00 pm
Hi, guys. I'm having problems with my render and muster is telling me to see the logs for details ... where are they? I'm on win2K runnin 6.0.1. A search in help mostly pointed to licensing logs and how to enable or disable it.
Thanks.
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
Sean Fennell
Re: render logs
on Sep 2, 2005 at 11:43:16 pm
I believe there is a master log file called maya.log or render.log in the MAYA_APP_DIR which defaults to My DocumentsmayaX.X where X.X is the version
mYthprod
Re: render logs
on Sep 6, 2005 at 4:10:11 pm
I sure don't see it. Is there an option in maya to not log? Maybe mine is turned off. I searched my entire C drive for *.log and it pulled up nothing related to maya that I could find.
- mYthprod
(John David Hutton)
Sean Fennell
Re: render logs
on Sep 6, 2005 at 5:30:42 pm
I'll have to look when I get to my computer, I'm sure its there somewhere, it may have a .txt extension on windows. Try doing a search for maya.* in the meantime.
mYthprod
Re: render logs
on Sep 6, 2005 at 5:53:29 pm
Just found it. Under usernameMy Documentsmaya called MayaRenderLog.txt. Wow, 69MB text file. heh. :-P
- mYthprod
(John David Hutton)
Sean Fennell
Re: render logs
on Sep 6, 2005 at 6:09:01 pm
yeah whenever you render anything in maya, either interactive or batch, it dumps the output into this renderlog file. You'll probably see entries from months ago in there. There is a way to re-route the log to another place, I think its an environment variable as well as the command line render command has a -log flag in the new versions.
