Deleting hair dynamics
COW Forums : Autodesk Maya
mYthprod
on Aug 22, 2005 at 8:13:48 pm
I'm building a tiki hut and I play to get the hair to fall over the surface of a nurbs cone and over the sides nicely. Once it's in a position how I like, how do I delete the dynamics so I just have a static, hair tiki hut roof?
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
mYthprod
Re: Deleting hair dynamics
on Aug 22, 2005 at 8:24:00 pm
I think I might've figured it out. I went to set rest position "from current", then set start position "from rest". Then I changed the simulation method to static. I don't know if I did it the hard way but it worked. :-P
- mYthprod
(John David Hutton)
Sean Fennell
on Aug 23, 2005 at 12:51:41 am
well, if you're never going to use the dynamics again you can simply delete history on the hairOut curves. But if you want to do some subtle wind in the tiki effects then you went about it the right way.
