copy selected
COW Forums : Autodesk Maya
mYthprod
copy selected
on Aug 22, 2005 at 4:35:47 pm
Is there any way to copy selected in the channel box to and from objects without keyframes assigned? I can temporarily key them then copy and select to the target object and the target object doesn't have to have keyframes applied, just trying to find a way to not have to key either and still copy attributes to and from objects.
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
anthonymcgrath
Re: copy selected
on Aug 24, 2005 at 10:54:30 am
I just copy the keyframes as you described then use cut straight after :/ then you end up with the values you want and no keyframes.
mYthprod
Re: copy selected
on Aug 24, 2005 at 2:19:22 pm
Thanks anthony. I'll use cut.
- mYthprod
(John David Hutton)
