Changing Scale of imported Scene - Help RQ
COW Forums : Autodesk Maya
cow
tom001
on Aug 19, 2005 at 3:21:07 am
Re: Building a Ship model:
1. I modeled the mast in a separate scene from my main hull. And the mast is at a larger size than I need, and I want to reduce it either before or after merging into the hull scene. If I try this with scale before merging it only reduces each object size, not the space between them, and if I try this after merging, I can't seem to select just the mast, even though I have it in a separate layer...
Any suggestions most welcome - Thanks! ~tom
Steve Sayer
Re: Changing Scale of imported Scene - Help RQ
on Aug 19, 2005 at 3:37:20 am
Group everything and scale the group node.
-Steve
tom001
on Aug 19, 2005 at 5:25:22 am
Thanks Steve - Worked like a charm. May I ask one more question...?
I have made the hull with birail, and I have a nurbs plane for the top deck. To attach these two planes, do I just select the points along both edges and 'attach nurbs'? Thanks ~tom
