medical animation for 4 chambered pumping heart .....
COW Forums : Autodesk Maya
on Aug 9, 2005 at 11:20:11 pm
medical animation, what is the easiest & best software for beginners?
I have heard of maya, studio 3d max, Eovia, I am confused
I need to know which one or( which ones ) are best suited for ..
1. Constructing animations of say a heart pumping, with 4 separate chamber, & showing the blood as a stream of liquid blue arrows --->pumping from chamber number 1 [ RA } to chamber number 2 [ RV]... then to the lungs where inside the lungs the blood becomes red. then returns to the heart chamber number 3 [ LA] as a stream of red liquid arrows/.....> then pumped to chamber number 4 [ LV]... then leaving the heart ......
there will be sound available if needed for ' key framing if this is needed ....??
A 3d animation would be ideal, but a 2 d animation, made to look 3 d....would do the trick....
Once this is constructed, I then need to make variations on it to simulate heart defects.....
many thanks for at least reading this!!!!
Steve Sayer
Re: medical animation for 4 chambered pumping heart .....
on Aug 10, 2005 at 12:11:55 am
It sounds like you don't have animation experience or background, and only need to produce a small number of animations which are variations on a theme, for which simple, stylized graphics would be sufficient.
In that case, high-end packages like Maya and MAX might be overkill. I'd recommend you look into something simple like Flash, and start exploring other options only if that proves insufficient.
© 2018 All Rights Reserved
