Playblast freezes around 20 frames in - Regularly!!
COW Forums : Autodesk Maya
james stevenson
on Aug 7, 2005 at 4:59:55 pm
When playblasting animations I often find that the rendering freezes at around 15-25 frames in and the bottom left corner of the whole screen goes white.
I have no other apps running and I'm staying within Maya whilst previewing. Any ideas what's causing this? I've tried all the codecs etc to no avail!
Using Maya 5 and Maya 6 at work.
the_biggun
Re: Playblast freezes around 20 frames in - Regularly!!
on Aug 17, 2005 at 8:41:31 am
I assume you are running Win XP. if so then right click the maya icon on your desktop > > propertie > compatibility > and select to run in windows 2000 mode from the drop down. click apply and your done start maya in the normal way and give it a try.
Dave
