Lighting > Shadows
COW Forums : Autodesk Maya
mYthprod
Lighting > Shadows
on Jul 21, 2005 at 2:51:11 pm
I found a tidbit on this in the help files. I'm going through a shadows section in my book and it mentions that "some" video cards support the Lighting > Shadows feature. If I create a spot and enable depth map shadows, would the Lighting > Shadows option turn on and be available for me to click? Mine stays shadowed out. I'm using the nvidia FX1100 card with Maya 6.0.
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
Sean Fennell
Re: Lighting > Shadows
on Jul 22, 2005 at 4:55:15 pm
Yes it will work with the quadro fx 1100. You have to be viewing lighting in the viewport first. All lights or selected lights hotkey: 7. Then you should be able to turn the shadow on. You can also use Hi-resolution shading in the viewport.
mYthprod
on Jul 22, 2005 at 5:14:08 pm
There we go. Thanks!
- mYthprod
(John David Hutton)
