text effect question
COW Forums : Autodesk Maya
lestDog
on Jul 12, 2005 at 2:57:54 pm
anyone have an idea how i could do this in maya? Not the red smoke put the particles that make up the name... thanks!
http://www.renascent.nl/m46b.htm
Glenn Moore
Re: text effect question
on Jul 12, 2005 at 4:19:45 pm
It just looks like a 'reverse' shatter effect. I haven't done anything like that in Maya before but I'm sure it can be done. Might be easier in After Effect.
lestDog
on Jul 12, 2005 at 5:36:38 pm
I forgot the shatter effect... That would be good.. thanks glenn!
lestDog
on Jul 12, 2005 at 5:35:35 pm
actually I would like to know of a solution for the red smoke as well.. but I thought it would be a better AE effect.. don't know
Glenn Moore
on Jul 12, 2005 at 8:08:10 pm
You're welcomed. Glad I could help.
It might be. Partcle Illusion has a lot of smoke effects but so does Maya. You could use a particle generator in Maya. I dont' do a lot of that. One of the pros here might have a really easy way to get that. It doesn't look too hard.
anthonymcgrath
on Jul 19, 2005 at 12:20:55 pm
yeah trapcodes particular for afx is fantastic - you could do that, have your text emit particles then render it out and reverse it :)
