reading alpha channel
COW Forums : Autodesk Maya
on Jun 30, 2005 at 10:31:32 am
Hi can you help ?
Alpha channels in a targa sequence I am using are not showing up in the image planes in my environmental camera rig.
Display mode is set to RGBA.... but still nothing ???
I remember having this problem before, but can't remember the fix ???
Any suggestions appreciated
Re: reading alpha channel
on Jul 2, 2005 at 8:29:37 pm
Take it into photoshop and check the channels and make sure an alpha exists. Turn it on and make sure the red shows up where the alpha should be. maya's a bit pickier how the alpha is set up than adobe products are ...
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
© 2018 All Rights Reserved
