Importing STL into Maya
COW Forums : Autodesk Maya
rumplefeik
on Jun 29, 2005 at 8:44:21 am
I have an ASCII STL file that I wish to import into Maya.
The file imports well into Cinema 4D but I need to be able to bring it into Maya. Is there a simple solution?
A plugin or program that converts this inot a Maya STL? This is a bit of a headache. Not my area of expertise.
Thanks in advance
Thomas Rydberg
Re: Importing STL into Maya
on Jun 30, 2005 at 9:35:29 pm
Perhaps you could convert it to a format like DXF which then could be imported into Maya.
Stereolithography (STL) file conversion to DXF should be possible. If you can't find a way, you might contact a rapid prototyping service bureau and see what they recommend.
- Tom
rumplefeik
on Jul 1, 2005 at 2:35:27 pm
Thanks for the response.
There was a simple solution. Maya allows import of STL files but you have to enable this option in the plugin manager.
Now I know. All is well
Ari Feblowitz
on Jun 3, 2015 at 8:54:05 pm
Really? What's it called? I'm not seeing it
Falconic Katadora
on Jul 11, 2015 at 5:51:36 pm
The plugin is called DirectConnect, not exactly the most intuitive name.
