Object fades in as it draws closer to camera
COW Forums : Autodesk Maya
mYthprod
on Jun 16, 2005 at 10:49:39 pm
I have an animation of a long object that's more visible the closer to the camera it becomes. Would it be easier to handle the transparency in Maya with something like fog (it has a white background) from a light or maybe it would be easier to handle the transparency in after effects with a z-depth render from Maya? I haven't used either very much (ie. not familiar with what kind of idiosyncrasies AE has with Maya z-depth renders) at all and this project has a short deadline.
TIA!
Jason Brummett
Re: Object fades in as it draws closer to camera
on Jun 17, 2005 at 6:24:19 pm
This is coming a bit late for your deadline but, I would render out a Zdepth pass if the shot is simple enough and do this in AE. That's the easiest but of course there are other elegant solutions such as keying the colormaps alphagain for instance and connecting this to your Maya Camera to give you no contrast or what ever your after if the objects far away and full contrast and brightness when closer. The distances can be regulated via a multiply divide node.
_Jason
Jason Brummett
Studio Z Inc.
bjohnston
on Jun 21, 2005 at 6:03:26 pm
You might attach a locator to the camera then write an expression that controls the level of transparancy of your shaders based on the position of a locator.
