Shatter, Earthquake, Wood/Iron snapping ect. - seeking inspiration.
COW Forums : Autodesk Maya
R303
by
on Jun 4, 2005 at 6:40:04 am
I'm doing an animation of an elevator-shaft. I'm leaving the inside of the elevator, through the vent. Going up the shaft along the cables and wires - all to the top. Here I want to see the wire snap! I want to see all the little iron-threds unwield and fly wildly around. I also want the cieling to colaps and debree fall down.
Now! Let me say at first . I'm not seeking a solution to a problem here. I'm not expecting you guys
sitting in all weekend and creating an earthquake for me.
I'm meerly seeking inspiration and a bit of guiding.
Where do I look to find something about making wires snap?
Where do I look to find something about making debree and rocks crumble?
Hope one of you could point at something.
Thanx.
Joaquin (Kino) Gil
Re: Shatter, Earthquake, Wood/Iron snapping ect. - seeking inspiration.
on Jun 4, 2005 at 9:33:52 pm
take a look at Digimation.com. They have a plugin called "Blast Code" that can simulate breaking things. It produces dust and debris as well.
.k.
R303
by
on Jun 5, 2005 at 10:08:15 am
Thank you. It looks quite good for things exploding and cracking/braking.
What about a cabel-wire snapping, with all the little threads unwinding?
Steve Sayer
on Jun 5, 2005 at 1:57:32 pm
[R303] "What about a cabel-wire snapping, with all the little threads unwinding?"
Depending on how much detail you want for that, you might be able to use PaintF/X. You can apply PF/X brushes to curves that you animate in your scene, and you can also animate many properties of the brushstrokes themselves, making them react to forces etc. You could probably get a passable effect with some fiddling.
-Steve
R303
by
on Jun 5, 2005 at 3:00:09 pm
Thank you guys.
I hope I'll be able to make it look realistic, because without that realistic atmos, my effect will come out like is't plastert on to the movie.
Again, thank you x 1000.
Dani
