gathering used files for archiving
COW Forums : Autodesk Maya
Mythprod
on May 28, 2005 at 2:40:44 am
I'm not at a maya station now but thought I'd ask while I was thinking about it - is there a feature in maya similar to after effects' "collect" feature where you can collect and organize all exterior files used so you can easily archive your project? I'm usually good about keeping my files inside my project folders but others in the office are not as anal. :-P
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
Mythprod
Re: gathering used files for archiving
on May 28, 2005 at 2:42:29 am
Sorry for the double. I was working in bins today and noticed it's very easy (for me at least) to forget to put materials where they belong until it's too late. I initially thought just being in a bin would automatically put new materials there but I was wrong. Maybe this is a 6.0 thing and they've improved it in 6.5?
- mYthprod
(John David Hutton)
Sean Fennell
on May 28, 2005 at 5:19:27 am
the command mayabatch -archive scene.ma on the command line will gather a list of all the files textures and references associated with a particular maya scene file for archiving purposes.
as for the bin activity in the hypershade, I don't think its changed in 6.0, I too was miffed that new materials weren't placed in the active bin.
Mythprod
on May 29, 2005 at 2:57:35 pm
Thanks, sean! That archive mel command will really be helpful. I'll read up more on this in the help.
On the bin answer, you meant it hasn't changed in 6.5? I was really disappointed you had to move things into the bin manually.
- mYthprod
(John David Hutton)
Sean Fennell
on May 29, 2005 at 5:20:14 pm
I haven't used it much since we're still on 6.0 at work, but I didn't find any mention of a change in the release notes so I assume it works the same as 6.0
