Morphing text to smoke
COW Forums : Autodesk Maya
mike skiffington
on May 9, 2005 at 2:45:38 pm
Hey,
I wanted to know if there is a way to morph text to smoke in maya 6. I'm sure I've seen a tutorial online a while ago about this but I can't seem to find it now. Any help would be great.
Mike
bjohnston
Re: Morphing text to smoke
on May 9, 2005 at 5:31:47 pm
You could use standard particles (emit from object) or you could use fluids (use file as source of fluid).
mike skiffington
on May 9, 2005 at 5:47:50 pm
Thanks for the reply.
Would both of those methods work using 3D text? I forgot to mention that in my first post. I haven't been able to give what you suggested a try yet because I've been working on a computer all day that doesn't have Maya ;)
Thanks again,
Mike
bjohnston
on May 12, 2005 at 6:34:32 pm
Yes. In a 3d volume use object as emitter of fluid. Standard particles will do the same. They will just render differently depending on the look you are after (and how much time you have). ;)
Glenn Moore
on May 14, 2005 at 4:24:50 am
There is a tut on the Maya site . I believe you have to be a subscriber (at least Bronze). Its a smoke to text tut using the Alias logo but it's really just reversed to create that effect. Search for this project:
Using Fluids to Form an Image by Tom Bardwell
