image sequences
COW Forums : Autodesk Maya
niall
image sequences
on May 3, 2005 at 12:06:28 pm
hi,
I have an image sequence applied to a transparency node but it continues playing after the sequnce has ended. how do I stop the image sequence on the last frame? I'm using maya 6.5 on osx, but i preume, as it's a relatively simple thing to do, it will be the same on every version of maya!
cheers
Niall
Steve Sayer
Re: image sequences
on May 5, 2005 at 9:49:54 pm
Hi, Niall.
You can keyframe the 'frame extension' attribute to manually control the playback of an image sequence.
Good luck,
-Steve
