cluster problems
COW Forums : Autodesk Maya
jdonnelly1977
cluster problems
on Apr 29, 2005 at 11:31:50 pm
I'm using clusters to animate eyelids opening and closing. I make them, center the pivot point to the center of the eye, and parent the cluster to the geometry of the head. Everything works fine until I advance in the timeline and the head changes positions. The cluster still follows, but it rotates the eyelids around the initial starting point of where I made the clusters, but the rotate tool is in the middle of the eye still. Why isn't the cluster actually rotating where it should be anymore?
jdonnelly1977
Re: cluster problems
on May 2, 2005 at 5:15:29 pm
Ahh, found the solution. It turns out that I needed to delete history of the eyelid before creating a cluster. For some reason the history was making its own transformations.
So if anyone else has a problem similar to mine, then be sure to delete history if nothing else works! :)
