zero-filling the numbers in image sequences
COW Forums : Autodesk Maya
Wagster
on Apr 21, 2005 at 5:51:15 pm
I'm a relative newcomer to Maya, and have a fairly elementary question: when you're rendering an image sequence, how can you get Maya to zero-fill the numbers so that After Effects can read it properly?
http://www.williamgadea.com
Chad Briggs
Re: zero-filling the numbers in image sequences
on Apr 21, 2005 at 7:27:11 pm
I'm assuming your talking about your sequences reading like myfile.0001.tga instead of myfile.1.tga?
in the render globals, look at frame padding. this tells maya how many zeros to put in.
-chad
Wagster
on Apr 21, 2005 at 9:14:03 pm
Great, thanks.
