Changing Scene Length
COW Forums : Autodesk Maya
Patrick
on Apr 4, 2005 at 5:15:50 pm
I need to speed up a scene that currently has a frame length of 300 frames. The timing of the animation is fine, it just needs to happen faster. Is there a way to make a global change of the key-frames to shorten the scene length by 50% without having to manually change each key-frame?
Steve Sayer
Re: Changing Scene Length
on Apr 4, 2005 at 5:47:01 pm
Hmmm, it's really very strange how questions sometime come in packs! A few people have asked this recently. The dope sheet is the panel you want. Do a search through posts for other suggestions, too.
-Steve
Chad Briggs
on Apr 4, 2005 at 6:08:04 pm
In addition to what steve said, you can also change the framerate in the animation preferences and it will scale the keyframes accordingly.
-chad
