rendering edges on a ribbon
COW Forums : Autodesk Maya
joe
by
on Apr 2, 2005 at 5:23:44 pm
I've created a ribbon following Chad's tutorial, however whenever I render it the edges are extremely choppy I have the settings set to Quality: Production Edge Anti-Aliasing: Highest Quality. If it helps here is a picture of it. http://www.excellentkicks.com/ribbon.jpg I tried tweaking the tesselation settings but it didnt seem to help. (although I'm not too familiar with them)
Chad Briggs
Re: rendering edges on a ribbon
on Apr 2, 2005 at 5:37:11 pm
defintely a tesselation setting. What do you currently have your tesselation set to? Select the ribbon surface and look in the attribute editor.
-chad
joe
by
on Apr 2, 2005 at 7:19:26 pm
by default (which was used for the image above)
Curvature Tolerance: Medium Quality
U Divisions 1.5
V Divisions 1.5
All others are currently off. Advanced and Secondary are off.
I tried changing curvature to Highest and rendered current frame inside maya and didnt see much difference
Jon W.
on Apr 2, 2005 at 8:25:03 pm
I haven't gone through the tutorial but off the top of my head it seems like your curve has too few points. Try selecting the curve you extruded the surface to, assuming you still have history on, rebuild the curve and add a bunch of more points.
Chad Briggs
on Apr 2, 2005 at 10:28:53 pm
what you need to do is crank up your u and v divisions. these attributes basicly tell maya how many polys to insert between each isoparm on a nurbs surface. turn on "show tesselation in shaded view" (or something like that) and when you adjust the uv tesselation, you'll see it get more hi poly and less hi poly in the shaded viewport.(it doesn't work in wireframe mode)
-chad
Sean Fennell
on Apr 2, 2005 at 11:03:37 pm
Hi Joe,
With the ribbon selected under Tessellation settings turn on Display Render Tessellation. This will show you in the viewport exactly how smooth the geometry will render. What might be best is to open the Advanced tab and turn on Enable Advanced Tessellation. You can increase both sliders until you get a very smooth result and a lot more polygons.
Maya's automatic tessellation is very well set up for primitives, but when you model your own geometry from scratch it tends to fall very short.
joe
by
on Apr 3, 2005 at 5:31:13 am
very heplful info thanks alot!
